reynoldston Lawn Pro Sep 4, 2014 #2 I would say you have a carburetor problem. Install a repair kit and clean the carburetor.
C ChevyII Forum Newbie Sep 12, 2014 #3 reynoldston said: I would say you have a carburetor problem. Install a repair kit and clean the carburetor. Click to expand... Did that going to replace hoses next.
M motoman Lawn Addict Sep 12, 2014 #4 Chevy . Overly lean mixture could be due to intake gasket or tube leaks causing you to compensate with choke setting. Check plugs for color after running.
