john deere lawn mower only runs with chock on.
I would say you have a carburetor problem. Install a repair kit and clean the carburetor.
Chevy . Overly lean mixture could be due to intake gasket or tube leaks causing you to compensate with choke setting. Check plugs for color after running.
