john deere l110
john pepper
mower turns over slow even with new battery. pull the plug and it spins fine not sure
SeniorCitizen
With an OHV ( over head valve ) engine the least expensive and often the most productive procedure is to adjust the valves, especially if that has never been done. This is after battery cable ends and posts have been cleaned until they shine.
reynoldston
The John Deere L110 has a Kohler Command single cylinder model CV491 which you will find has nonadjustable hydraulic valve lifters. I would think more about the battery post and cables.
