When I turn key yes there is power to starter!When the solenoid gets 12 volts DC from the key, does the solenoid output have continuity with the input? Or input to output same thing? In other words will power pass from the battery TO the starter as normal?
Key switch is supposed to send power to the solenoid when in the cranking position. Is it doing that? If so, then the solenoid pull-in winding is not working to activate the starter so it will crank the engine.
It is!Key switch is supposed to send power to the solenoid when in the cranking position. Is it doing that? If so, then the solenoid pull-in winding is not working to activate the starter so it will crank the engine.
Now investigate what the Big 3 or 4 is in car audio. About upgrading powers and grounds stuff. Youtube has many videos to learn from.Took a ground from battery to engine mount and she came back to life!!
