TylerFrankel1
Hey everyone quick question, just need some advice.
Long story short, I restore junk mowers to sell. I'm working on one with a sheared key. I used a puller on the flywheel but a bolt broke off in one of the puller holes. So, I drilled a new one closer to the center of the flywheel and pulled it with that. I don't think it's cracked. If it was for me I'd be perfectly comfortable using it but because I'm going to sell it I want a second opinion on it's safety. After replacing the key and reassembling it runs fine an everything, though with a bit more vibration than a different mower I compared it to. Nothing awful. So, should I be ok?
Thanks!
I can get the model no. if you really want but it shouldn't matter for this, it's more of a general question.
Thanks!
