I have a 4231 with an intermittent no start condition. Traced power to the starter without issue so I replaced it. Also using a brand new battery I got from a friend. Still intermittent won’t crank. Relays click and fuses have been replaced.
Any ideas? Neutral switch has some play so I put a spacer in there, no change. Not a whole lot left to look at. Ignition switch maybe?
Intermittent is tough to diag unfortunately
