Mad Mackie
Hi troops,
I have a 2008 Scag Tiger Cub with a 26 HP Briggs ELS twin. Last summer it started "sneezing" periodically. I found the L/H cylinder to have much lower compression than the R/H cylinder. Further testing with a leakdown tester showed leaking by the rings. Subsequent leakdown testing indicates and increase in the leakage rate.
I removed the heads but found no scoring on the cylinder walls. This engine has 500 hours on it and I operate this machine in dusty conditions with a collection system most of the time. Sometimes I have to replace the air filter after 15 hours and do oil changes more often than scheduled.
I plan to repower this machine with a new Briggs 30 HP Pro engine that has the cyclonic air filtration system. I would prefer a Kawasaki FX730, but the cost of the Kawasaki repower is more than twice than the Briggs. I love the Kawi FX 730 on my new Hustler X-ONE and would love to have the same power on my Scag, but the dollars just don't work out for me. The Hustler is a rear discharge machine which is used almost exclusively for cemetery mowing.
Later
Mad Mackie in CT:laughing:
Later
