Aaron.Dieringer
Ok, so i have a MTD Huskee model # 14BS833H131 and the Trans pan has a slight leak. So every so often (maybe once a year or once every two) i would have to top off the trans oil. I used 20W50 and have had zero issues. Since im re doing my shed and the mower is in the garage i figured id address the issue. So i dropped the pan and replaced the gasket and put everything back together and filled with oil. Now the thing will not purge. I can not get it to move at all. Ive searched just about every thread out there and tried everything ive came across. What ive noticed is that if i put the motion control forward and pull the relief lever in and out quickly the wheels will start moving forward but as soon as i stop the wheels stop. Ive tried leaving the relief open and leaving motion control forward for a few seconds, then reverse for a few seconds, then pushing relief lever in and the wheels move forward for a second or two. Ive been at this for about 2 days now and have not made any progress. I have tons of money in this tractor as i like to keep things in working order and dont want to give up just yet and i cant quite justify spending a ton of money on a new throw away tractor. Not sure what has happened between now and 2 days ago when it was moving fine. Any help would be greatly appreciated!
