Hustler Raptor SD Discharge Trouble
Glad you got that worked out for the smaller unit too. Sort of amazing what a few hundred RPMs will make. I checked mine and it was dead on for high idle at 3600.
Yeah the hi lift blades are awesome,,they suck up all the little twigs,pine cones,and what not,,then chop it up real good,,the stock blades dont have much lift at all on my 54.
Just ordered similar tach. Does it matter where on the spark plug wire you wrap it? The Raptor has 4" of wire showing from the plug before it goes under the cover. Can I wrap it that close to the plug?
Yes,it doesn’t matter,,as long as you get 5 or 6 wraps on it you will be fine,,the one on my Husky is right up against the boot which is really close to the valve cover.
