Mowed the field yesterday, and it was nice and thick. Deck did not clog or get build up since I removed the triangle from the discharge chute. Very pleased with the way it throws and disperses. I wonder why Hustler has the triangle blocking the discharge? Using high lift blades, and the clippings shoot out 10 feet or so with no clumping. So for now, I won't cut off the bar across the discharge opening.
Rear tire has a leak in it. I can pump it up and mow for an hour, but by the next day the tire is completely flat. Must have picked up a nail or something. Took the rear wheel off and will fill up the kiddie pool tomorrow to find the leak and then take it to the local tire shop. Hopefully they can plug a mower tire.
Local Hustler dealer is having a free pancake breakfast tomorrow. Tempted to stop by, get breakfast and talk to them about the new SDX. Maybe even consider upgrading to the 60" Fastrak. Wonder what the trade in value is on my RSD with 30 hours. I'm sure I can't afford it!
just buy a gallon of slime and fill the tires and never worry about leaks again.
supposedly the sdx costs 700 to 800 more than the sd.
