Hustler M1 Push mower
Ric
If anyone is interested in a push mower this one mite be worth taking a look see, The Hustler M1 commercial
* 5.5 hp Honda commercial-grade OHV 4-stroke engine
* Shaft Drive - 2nd PTO shaft to power gear drive (no belts)
* Twin blade mulching system
* Heavy-duty, yet light-weight, cast-aluminum deck
* Heavy-duty, reinforced, 1"-diameter handles
* 7 cutting heights: 7/8" to 3.25"
* Heavy-duty, aluminum wheels with ball-bearing hubs
* Extra-large discharge opening allows better flow and distribution of grass clippings to improve mowing efficiency and finished appearance
* High-capacity, 2.7 cu ft grass bag is easy-on, easy-off
* Blade Brake Clutch - stops blade, not engine
* 21" mulch/catcher
* Front Bumper and Edge Guards to protect deck
Sounds interesting to me, but I have a couple of questions. 5.5hp seems a little under powered. Looked all over the web, can't find a price tag. Does Excell industries build this mower or is it a product manufactured by someone else with the Husler name?
Ric
I don't know, it came up when LMF found a picture of the mower on the Mojack lift and thought it was a Hustler so I did a search, I only found the thing on one site and it is not mentioned on the Hustler site that I can find. I'm wondering if they even make the mower anymore.
cell6ida
Did I read this right? The highest cut is 3.25 inches? I guess you can't cut St. Augustine with it, which should be cut no lower than 4 inches.
MRCo.
It's irrelevant as this mower is long gone. Many pushers top out under 4".
