Ric
- May 7, 2010
- 5,765
If anyone is interested in a push mower this one mite be worth taking a look see, The Hustler M1 commercial
[TD="align: left"] 5.5 hp Honda commercial-grade OHV 4-stroke engine [/TD]
[TD="align: left"] Shaft Drive - 2nd PTO shaft to power gear drive (no belts) [/TD]
[TD="align: left"] Twin blade mulching system [/TD]
[TD="align: left"] Heavy-duty, yet light-weight, cast-aluminum deck [/TD]
[TD="align: left"] Heavy-duty, reinforced, 1"-diameter handles [/TD]
[TD="align: left"] 7 cutting heights: 7/8" to 3.25" [/TD]
[TD="align: left"] Heavy-duty, aluminum wheels with ball-bearing hubs [/TD]
[TD="align: left"] Extra-large discharge opening allows better flow and distribution of grass clippings to improve mowing efficiency and finished appearance [/TD]
[TD="align: left"] High-capacity, 2.7 cu ft grass bag is easy-on, easy-off [/TD]
[TD="align: left"] Blade Brake Clutch - stops blade, not engine [/TD]
[TD="align: left"] 21" mulch/catcher [/TD]
[TD="align: left"] Front Bumper and Edge Guards to protect deck [/TD]
