Ric
 - May 7, 2010
- Threads
 - 139
 - 5,765
If anyone is interested in a push mower this one mite be worth taking a look see, The Hustler M1 commercial
			| * | 5.5 hp Honda commercial-grade OHV 4-stroke engine |
| * | Shaft Drive - 2nd PTO shaft to power gear drive (no belts) |
| * | Twin blade mulching system |
| * | Heavy-duty, yet light-weight, cast-aluminum deck |
| * | Heavy-duty, reinforced, 1"-diameter handles |
| * | 7 cutting heights: 7/8" to 3.25" |
| * | Heavy-duty, aluminum wheels with ball-bearing hubs |
| * | Extra-large discharge opening allows better flow and distribution of grass clippings to improve mowing efficiency and finished appearance |
| * | High-capacity, 2.7 cu ft grass bag is easy-on, easy-off |
| * | Blade Brake Clutch - stops blade, not engine |
| * | 21" mulch/catcher |
| * | Front Bumper and Edge Guards to protect deck |
