- Nov 29, 2014
- Threads
- 64
- 24,729
And I don't think it will be enough to run the electric PTO and recharge the battery so you will most likely have to hook up to a trickle charger after each mow.
Get it to me, in Australia ?
You should have one of these
The red wire should be DC + and goes to the battery or the ignition switch Terminal A ? check your wiring diagram.
The black wire is AC and goes to the headlights.
