hustler fastrac 44''
And I don't think it will be enough to run the electric PTO and recharge the battery so you will most likely have to hook up to a trickle charger after each mow.
Im pretty sure it's the second one that's the one that best compares out of the 4 best i can tell From the wires anyway
Sounds like you need to find a small engine mechanic locally that works from his yard to help you or give you advice after seeing what you have.
