HELLO ROBERT ,, I NEED INSTRUCTIONS ON TRANSMISSION REMOVAL AND THE BLEEDING PROCEDURE . SHOP MANUAL INSTRUCTIONS WOULD BE HELPFUL . WHEN BLEEDING THE TRANSMISSION IS THERE A PRESSURE INSIDE OF THE CASE ? IS THERE A POSSABLE CHANCE OF OVER BLEEDING?Hi Michael:HELLO ROBERT ,, I NEED INSTRUCTIONS ON TRANSMISSION REMOVAL AND THE BLEEDING PROCEDURE . SHOP MANUAL INSTRUCTIONS WOULD BE HELPFUL . WHEN BLEEDING THE TRANSMISSION IS THERE A PRESSURE INSIDE OF THE CASE ? IS THERE A POSSABLE CHANCE OF OVER BLEEDING?
MY HANDLE IS [email protected]
The HST fluid lasts a long, long time. Unless it's leaking, there's no need to check/change it. In fact, the shop manual says:
HST oil will darken during use and may appear to contain fine metallic particles or residue. This is normal, and does not indicate excessive wear or an internal failure.
Now, if you may have spilled some, so if the mower isn't performing (drive) as it used to, it's possible the fluid level is low.
To add fluid, the entire transmission must be removed from the mower. Place the transmission on flat, level surface, and there's a large round cap held on with two bolts. Remove the cap and diaphragm. Add fluid to fill to the top of the case. Most important, only used genuine Honda HST oil. No other brand or type of oil is suitable for use in the transmission. You can get a quart (part number 08208-HST01) from any Honda dealer; here's a link:
Honda Dealer Locater
If you need help removing the transmission from the mower, reply back with the frame serial number (it's on the back edge of the deck, in the form of "MXXX-1234567") and I'll post a few pages from the shop manual with the full procedure.
Finally, if the HST fluid level is very low or nearly empty, adding fresh fluid then doing a bleeding procedure is necessary. If you need it, I'll post those pages too, just ask.
MAGA-1315314
HRX537
