MichaelT1960
- Nov 27, 2012
- 2
My mower hesitates moving when it is cold. The transmission seems to need some fluid. Already adjusted the cable and that initially helped.
Does the hydrostatic transmisson need to be removed for this? I found a bolt to remove with the mower on its side but the fluid started coming out and I had to put it back! Fluids color was was not clear but greyish looking and has never been changed in 15 years of use (3 - 4 of them in storage).
Thank you,
Michael
Thank you,
Michael
