today i worked on this unit,i replaced his transmission with a used one replaced the blades,removed carb, cleaned,adjusted the valve cleance ,zerode out the mechanical governor.all the latter because of surging,and he says it ran quieter before,did i miss something? do something wrong? top no load RPM was 2850,
