Blade Runner
They are in your state. I recommend you call them and find out their specific location. Might be cheaper and better to drive their and inspect their engines before you buy it. No matter what, I would call them before buying and find out how they rate their engines and what warranty (if any) do they have on used engines. For example, at an auto salvage, they will tell you how many miles were on the engine before it was pulled. Some salvage yards will give you a waranty that the engine will run and thats it. At some places you buy as is. Therefore, I would call them and ask a ton of questions before buying.
An 8hp on up, vertical shaft will work. Even if the engine mounting bolt holes do not match, you can drill new ones. The easiest thing would be to get a newer version of what you have. I prefer Briggs I/C single cylinder engines and would put a 12hp to a 15 hp engine on a Snapper rear engine rider (unless I decide to upgrade the transmission pulley/disk system, then I might go for the 18hp).
