mikeypizano
I was wondering if someone, like Robert, can post pictures or part of the maintenance manual, on how to do this? I know clearance should be at 0.006" on intake and at 0.008" on the exhaust.
So you are trying to tell us that 0.0001 " is going to put a mower engine out of spec ?
Can I reuse the gasket or do I need to replace it even if its not damaged? I will pick up some feelers this weekend. I hope I can trust the Harbor Freight ones.![]()
No need to replace the gasket if it is in good shape.
