MY HONDA MOWER DOESNT PICK UP GRASS,IT LEAVES A TRAIL ON THE RIGHT SIDE OF MOWER AFTER MOWING,I HAVE TWO OF THE SAME KIND OF MOWER AND THE OTHER ONE DONT HAVE SAME PROBLEM
On the back of the mower deck is the frame serial number, in the form of MXXX-1234567.
1. Has it always had this problem?
2. Are your other two HRC exactly the same, precise model?
3. Describe your mowing pattern. Up-n-Down stripes, round-n-round until you get to the middle, etc.?
4. Are you bagging, discharging clippings, or mulching?
5. Is the mower 100% stock with original Honda blades? *ANY* modifications at all?
6. Borrow or use a tachometer to correctly measure engine speed; what is it when the blades are engaged?
7. Do you mow in the same pattern / lawns with the problem mower as you do with the other Honda mowers?
8. Is the grass tall/short, wet/damp/dry, what kind of grass (bermuda, fescue, rye)?
9. Using BOTH OEM blades, or just one? Which one?
10. Anyway you can post photos of the lawn AND the underside of the mower deck?
11. Look close, and each of the two blades has a part number stamped; can you tell me what they are? XXXXX-XXX-XXX
