kevin paul
I was given a honda ht r 3009 riding mower. There is a small hose from the carb to a part called the gas catcher. When I open the valve to allow fuel to the carb it goes through to this part, wich is mounted on the frame close to the carb. there is a nipple for another hose on it, but no hose. Also, there is a hole in the bottom of the gas catcher. I don't Know what this part is for or how it should be hooked up.The mower tries to start if I prime the carb, but dies in a couple of seconds. I have not tried to start the mower with the fuel shutoff valve open because the gas runs out on the ground.If I open the fuel shut off valve, the gas starts draining through the gas catcher. I have not been able to find a diagram that shows how to connect this.
