Honda HRX 217 Transmission Troubles
renochs
I have a Honda HRX217 self-propelled mower that is not self-propelling.
S/N is MAGA-1408598, so I think it uses part # 20001-VE5-A01 (Harmony Hydrostatic Transmission)
My first thought was to adjust the cable, as the resistance had gotten a bit slack, so I tightened it and it felt better, but still did not move much. It would pull itself along on flat ground, but had no power.
Next I replaced the drive belt (which was harder than it sounded), but the situation is the same. So I am down to the transmission.
Question: should I try to service the transmission, or just replace it? It's a bit of a pain to get to, even to refill the oil, and I haven't seen any evidence of fluid leaking. Is it likely that adding fluid would help this situation? Are there other fix-able things that go wrong with these transmissions? I don't mind doing whatever work it needs, but don't want to waste a bunch of time taking it apart and putting back together multiple times. At the same time, I don't want to drop $200 on a new transmission unnecessarily.
Does anyone have experience with this? Thanks!
http://www.hondapartsnation.com/oemparts/c/honda_power_equipment_lawn_mower/parts
http://www.hondalawnparts.com/pages...SSION_(2)/HRX217K1-HXA/2414VH7401AVH74F0601GA
great prices, ship fast to your door
http://www.hondapartsnation.com/oemparts/a/hpe/505ce4a9f870022d24bdc765/transmission-2
remove spark plug for safety, keep right & left side parts in order & separate, take your time, if you don't have a workbench a pickup truck bed works great, place boards under deck at rear so back wheels can be removed first, belt, etc. let us know how it goes.
Hmmm...that serial number is coming up as a SmartDrive (not Hydrostatic). Do you have grey ground speed control in the middle? That's a SmartDrive model (VKA) not a hydrostatic type, FYI...
Anyway, I've got some extensive troubleshooting document for that mower's SmartDrive; drop me a Private Message with your email address and I'll send it to you:
Two Final Things:
1. You have a "K1" version, so pay attention when going through the document, as it covers K1~K6 models.
2. According to the records here at Honda, there was Product Update for your mower issued back in 2008 to correct a possible issue with hard starting of a cold engine. You may or may not have this issue, but if you are, there is an improved carburetor that will help. Let me know if you are having any cold-starting issues, and I'll get you more details.
Hi Robert@Honda. I have the HRX217K5VLAA serial MAGA-2789822 and am also having problems with the propulsion which I purchased on 6/18/2018. It worked great all summer the first year. Last year it seemed I had to squeeze the Smart Drive Control more to go and this year, fully squeezed/opened up, it doesn't work at all. The first two mows it helped only very slightly, but as of now, nothing. I don't know how to send a private message, but I see where you offered some extensive troubleshooting document for the Smart Drive. Any help would be greatly appreciated. Thank you.
Did you receive that document from Robert? I am having the same issue and would like to read through it.
Could be the belt. Sometimes the plastic bushings that support the drive shaft are so worn the transmission cannot compansate and the speed drops that way.
The issue was actually the drive cable which I thought was working properly. Once you mentioned to adjust it, I went out to the garage to do that and the self propel started working. Thanks! Now I don’t need to waste my time replacing the belt.
