nagsheadlocal
- Jun 10, 2013
- 2
Good morning friends -
I have a Honda Harmony 215 mower that ran perfectly until the oil pan gasket started leaking. So I disassembled the engine and replaced the gasket. Now the engin starts, but will only run for a few seconds very slowly. After poking around, it seems like the arm for the governor is frozen in place. I took the oil pan off again, and the arm moves freely, but when I put the oil pan back on the arm is frozen again. There must be a trick or some alignment to the governor arm inside the case that I'm not aware of. Any info or advice would be gladly received.
Mower info:
HRM215E3
Model SXA
Engine name GXV140
Engine type MA1
Engine serial GJAB-6630077
Frame serial M2BB-6148889
Thanks in advance!
Mower info:
HRM215E3
Model SXA
Engine name GXV140
Engine type MA1
Thanks in advance!
