Honda H3011 starter
Dave W
I'm new to the forum and could use some help. I have a Honda riding lawnmower H3011 H, hydrostatic with starter problems. Checked all of the safety switches and ignition switch all of which were okay. Pulled the starter and it failed a bench test. Solenoid works and 12.41 volts go to the starter but starter drive gear does not move up and motor does not whir into life. New starters run between $358 and $411. A bit more than I want to put into an older mower.
Wondering if anyone rebuilds this starter or if there are starter rebuild kits available out there.
Thanks.
Dave W
mechanic mark
Dave W
Plano Power Equipment Online Store - Honda H3011HSA Common Parts
Take your starter apart, brushes are probably shot, and inspect all parts, solenoid, gear teeth, etc. A new set of brushes and new solenoid should take of it unless you find something else during inspection.
https://www.partstree.com/parts/?lc...JPN,+VIN#+MA1T-5100001&dn=241475107514E0700AA Illustrated parts breakdown for your starter.
Mechanic Mark
Thank you for the information will pull the starter apart and go from there.
Dave W
robert@honda
Thanks.
Dave W
Hi Dave:
- Not aware of any aftermarket or OEM rebuild kits for this starter. Most of the component parts are still available from Honda, so if you can figure what exact/specific part(s) have failed, odds the original starter can be brought back to life (maybe). You may have a local shop that can do starter repairs/rebuilds, provided you can obtain get the new Honda parts.
- Attached are a few pages from the shop manual with more details, and also the parts listing for the starter motor.
- And the link to find a Honda dealer in your area. Beware, most shops are very busy this time of year, so be patient. Find A Honda Dealer
Be sure to click off SERVICE and RIDING LAWNMOWER and key in your ZIP code:
  • H3011H starter pages shop manual.pdf
  • H3011H starter parts list.pdf
Dave W
Thank you for the information and the attachments. It is a big help having something visual. Have pulled the starter apart and looks like the brushes are the likely problem.
Dave W
Briana
Welcome to LawnWorld!
We moved your thread to the Honda forum.
