Lawnranger
- Apr 18, 2012
- 6
- 671
Hello everyone,
I'm new to this forum but not to small engine repair. I'm more familiar with B&S engines than anything else but I'm working on this Honda powered walk behind mower that belongs to my friend that has a no spark condition. Here is what I've done so far - checked for spark using two different spark checkers, checked primary ignition cut off switch that attaches to the small lead on the bottom of the coil (the switch ohm's out at close to zero when closed and infinity when open), removed coil and cleaned both flywheel magnet and coil, used a standard business card to set coil/flywheel gap and still no spark.
I'm thinking that the coil is bad but wanted to ask if someone else has any ideas or could tell me what I'm overlooking. Is there a way to test this coil??? This is a gxv140 engine on a craftsman mower deck. The mower deck s/n is 917376370. I went to Sears website and found that the engine is no longer available and there is no information on their site. This is an older honda engine and I cannot locate any other designation for the model number such as build date/code. Any advice is appreciated.
Thank you,
Lawnranger
Thank you,
Lawnranger
