I have a Troybilt 21" mower that has a Honda GCV160LAS3H engine.
The Honda owners manual says this for the Spark Plug:
NGK-BPR6ES Pressure washer applications
NGK-BPR5ES All other applications
To me that means I should be using the NGK-BPR5ES plug.
Then the Honda manual for the GCV160 engine manual says to use the NGK-BPR6ES.
Which one is correct? I got this mower used, and it had the NGK-BPR6ES plug in it. When I removed the plug, it was really black and burned up pretty bad.
It would be great if someone who had a Troybilt 21" self propelled mower with the GCV160 engine would tell me which plug they are using.
Thanks
Zeek
Thanks
Zeek
