I have a model 20200 Timemaster 31200 serial series. I removed the spindles and the black plastic cogged pulleys to clean the spindle shafts and bearings. I am asking if anyone knows if these pulleys are installed with the metal double d shaped center up or down.
One dude of the pulley has a completely round metal center and the other side has the double d. What is the correct orientation double d side facing up to the sky or down facing the blades.
Thanks
Spit
Thanks
Spit
