Time cutters have seat switches that go through the brake module & the switch needs to be closed to crank the engineNo seat switch is only active when the park brake is off. You can start the mower with the park brake set and not be on the seat. On most mowers
And yes the parking brake is activated by the lap bars being fully out, A PIA when servicing because of the timer .
