Thank you,
The numbers are Model 3p877, type 0110 E 1, code 06042oze. I took the valve cover off as advised, one of the valve studs was backed out of the head at least a turn and a half, this allowed the cap on the top of the valve to fall off, I put the cap on and tightened the stud with a wrench on the stud, thinking that the nut would turn on the stud before the stud was tight and throw the valve out of adjustment. I put the valve cover back on .It started right away and seems fine now. I think I'm going to take it apart again and put some lock tight on the stud.
thanks for the advice.
