HELP..briggs & stratton popping or backfiring through the carburetor
I have the same problem 19 hp but I would almost say exhausting through the carb. it runs but putting some exhaust out the carb..what should the compression be ? its around 75 psi seems out of time maybe? any ideas?
Remove the valve cover and have a look, put up the engine's numbers, which are likely on or near the valve cover.
You could have a sticking valve, loose seat, sheared flywheel key, but don't keep running it, or you could have a pile of rubble....
Thank you,
The numbers are Model 3p877, type 0110 E 1, code 06042oze. I took the valve cover off as advised, one of the valve studs was backed out of the head at least a turn and a half, this allowed the cap on the top of the valve to fall off, I put the cap on and tightened the stud with a wrench on the stud, thinking that the nut would turn on the stud before the stud was tight and throw the valve out of adjustment. I put the valve cover back on .It started right away and seems fine now. I think I'm going to take it apart again and put some lock tight on the stud.
thanks for the advice.
Get a set of feeler gauges and adjust the valves too! Do it right, and it won't keep being a problem. Yeah, Loctite is a good idea.
sounds Good I Have feeler gauges, what should they be set at? do you know? and do you set them running? or is there another way?
thanks again.
