l008com
- May 25, 2015
- 337
I have an otherwise pretty nice Husqvarna 2 cycle gas weed wacker. AKA Trimmer. It's about 5 years old. It has two problems, which I'm sure are the same problem. And it's had them since it was new. Rather than fighting with this thing every week, I really should just fix it.
Symptom 1:
It dies if you let it idle. It will run with the choke partially on but with the choke fully off, it will slow down and usually in a few seconds to a minute, it conks out. It seems to die faster when it's fully warmed up, than when it's cold.
Symptom 2:
If it is idling or close to it, and you pull the trigger to rev it up to operating RPM, it will bog down and potentially stall out if you pull the trigger too fast. If you raise the RPM slowly, it gets up to speed and then it can handle the higher RPMs just fine.
I do NOT think my problem is that I need an idle screw adjustment. I think my problem is that the air/fuel mix is off. But I'm not sure if that can be adjusted, or how it can be adjusted. It's been doing this since it was brand new, and it still otherwise runs like it's new. So I don't think it's being caused by any other typical "old engine" problems.
But I'm no mechanic so maybe I'm totally wrong.
Also note, I've always run it with 1 ounce of seafoam in the gallon of oil gas mix. So I would expect the insides of the engine to be very clean.
So what do you think?
Symptom 1:
Symptom 2:
