FH580V spring
does the spring slide over the rod coming from the governor to the carb?
If so,it goes into the hole that the governor rod goes to on the carb.
I assume it's this spring, is long and skinny?
It's the other spring which is much short and stouter. I figured it out. Thanks for your reply.
