gregjo1948
Where does the governor spring attach at the opposite end from the governor arm? thanks, gregjo1948
does the spring slide over the rod coming from the governor to the carb?
If so,it goes into the hole that the governor rod goes to on the carb.
I assume it's this spring, is long and skinny?
