- Nov 29, 2014
- 24,995
Ok it goes like this.
When you pull the throttle fully open, the throttle wire pulls on that big spring on the bottom which pulls the governor arm ( the bit that come out of the engine ).
The top of the govenor arm is connected to the throttle linkage which goes to the throttle butterfly at the carb.
When the engine is not running , pulling the throttle on fully should move the throttle link far enough to make the butterfly open and rest against the stop which in your photo is not happening.
So the metal ( not the plastic ) arm on the carb should be as far counter clockwise as it can go. This is wide open.
The tiny spring over the throttle linkage that looks like it is pulling against itself is there to smooth out the movements of this arm.
If you push & pull the arm you will see a tiny amount of stretch in this spring it is just a damper
When the engine is running the governor pulls on the throttle rod which will close down the throttle butterfly and make the engine go slow.
So I will guess that the Govenor arm is in the wrong position, or the govenor spring is in the wrong place.
Now I did notice that you have buffed the magnets on the fly wheel.
This is a no no as you can affect the strength of the magnets by doing this carelessly.
If you want to remove the rust then use a rubbing block with some wet , wet & dry paper.
Now when you did this that will have changed the air gap and the air gap controls the spark timing so it will have to be reset.
To take things any further we need to know the engine details which should be stamped ino the engine cowel near the spark plug.
