winstonwolf
Hello,
I have a Briggs and Stratton intek edge 7.0 engine in my lawn mower with number 12h602 0545 b1. I got it from a friend. At the beginning the engine did not start, with some break cleaner through air intake it started but it did not stay on. I decided to clean the carburetor, primer pump and air intake system. There were some small impurities but it did not look very dirty. After cleaning the mower starts immediately but same problem, it doesn't stay on. It seems that the enginge does net get enough fuel, but why ? The tank ventilation is ok, no filter, no fuel valve, fuel tube is ok, fuel is fresh, spark is there. Even if I open the throttle by hand the engine stops. Any I idea? Still dirt in carburetor ? Should I change the sealings? They still look ok. Thank you in advance!
Regards
Regards
