Engine acts like it has too much compression
sears_custom
I have a Briggs & Stratton 16HP 402707, its in a lawnmower I have pulley swapped and done a lot of custom work on, I had to take the starter off because it went bad and wasnt cranking my engine correctly, I put a pulley on top of the engine and I started pull starting it.
Recently I have had trouble starting it, it acts like it has like 4x more compression then usual, sometimes it acts like normal though.
I have absolutely 0 clue what could be causing this as it happens completely randomly, it might have something to do with only being hard to start if it was running earlier that day but i havent really confirmed that yet.
I'm going to put a compression tester on both cylinders next time this happens and I'll update you
if you have any idea what this could be please let me know
Have never seen an engine with too much compression , test your starter - battery and all connections including the solenoid then post your results
The most common service item is to correctly adjust the valve lash. Has engine parts wear the valve clearances change.
When this happens the compression release mechanism stops working consistently.
There are lots of good videos online about how to do this, but you need the correct tools and a little patience.
I have heard that you may need to adjust the valves.
for some reason somebody I know told me that I dont have to do this on a flathead, I dont know why I trusted them because every other person has told me to do this, this is probably my issue but it still confuses me how it only does it sometimes. I'll adjust them tomorrow if I can
On the oppose V-twin engines like this, it is a little more involved because the valve clearance has the be checked and then the valves removed one at a time and the tips lightly ground to get the correct clearance. This is tedious exacting work.
There are videos online that go into detail about how to do this on the opposed V-twin Briggs and Stratton engines.
If you are not mechanically inclined and do not have the tools, I suggest you look around for an older small engine mechanic who can easily handle this. Newer small engine mechanics do not have a clue except how to replace an engine (maybe).
Normally on flat/L-head engines the valve gap gets less not more which would result in less compression. OHV engines tend to open their valve clearances but L-heads close their gap until they valves don't close. So I suspect the OP has something else causing the appears to be higher compression issue.
Or if running very rich, carbon can build up on piston and that can increase compresion..
