Engine acts like it has too much compression
sears_custom
I have a Briggs & Stratton 16HP 402707, its in a lawnmower I have pulley swapped and done a lot of custom work on, I had to take the starter off because it went bad and wasnt cranking my engine correctly, I put a pulley on top of the engine and I started pull starting it.
Recently I have had trouble starting it, it acts like it has like 4x more compression then usual, sometimes it acts like normal though.
I have absolutely 0 clue what could be causing this as it happens completely randomly, it might have something to do with only being hard to start if it was running earlier that day but i havent really confirmed that yet.
I'm going to put a compression tester on both cylinders next time this happens and I'll update you
if you have any idea what this could be please let me know
