reynoldston
They can warp. Fab decks can to but not as often.
This is a new one on me. So these decks are warping so bad you are getting a in-even cut. The only way I can think of to test for such a happening is to strip the deck and lay it on a flat surface. Just where do these decks warp?? So just how do you test for a warped deck when a customer comes into your shop? Or are they warping where the spindle housing fastens to the deck housing? If this is the case how do you repair it, shim the spindle housing so the blade is level? Is there a repair? You are saying just a linkage adjustment??? So you have a warped deck with two or three blades just how do you make them all level?? I just don't see these linkage adjustments on the low end mowers?? I don't see spindle adjustments on any mower other then a Ferris???
