VegetiveSteam
- Jun 1, 2022
- Threads
- 0
- 392
I guess I'll sort of start over with my reply as I just gave my opinion on the question about the chunk out of the cylinder. If i found no other damage to the block and the bore was in good shape and ring travel did not enter into the broken area, I would have no problem trying get the engine up and running if it were my own and not a customer's. I'd probably lightly hone the cylinder and install new rings. Since it does belong to a customer, I might have to decline trying to repair it.Ok, I have one more question. Do you think I should replace the piston rings since I have to remove the piston anyway?
If you do go forward with it, I would start by measuring the cylinder and see if it would need to be bored. If it does, you would then need to find out if an oversized piston is even still available for that engine and now, you're getting into the probably not worth it area.
