Since we do not have enough info to give detailed instructions it will have to be generic without pictures and the extra stuff.
Breather tube is connected to the bottom or side of the air filter housing and goes to engine. You remove air filter housing and blow carb cleaner in the tube. Then change oil and put back together.
