Convert 190402-1515-01 to Electronic Ignition
agdodge4x4
I have an old engine that has no spark. We suspect its the points and condenser. I'd like to convert this to Magnetron and avoid pulling the fly wheel. I am unsure of which kit I need to do this. What part do I need?
Seems like I need 398811.
398811
Romore
The quickest and most effective solution is p/n 398811 Armature, cut the wires going behind the flywheel and install. Cheaper but a little more work is p/n 394670 Magnetron kit.
WRONG PN. That pn is a bell crank.
Romore
OOOPS! 394970 is the correct number. My bad!
tom3
I've always wondered how you crank a bell?
  • 080200 Series Example 080202-8140-99
Now where is my points? :p
As for the 394970 it is no longer available from Briggs.
