Technically yes, the nut should be torqued on the top of the spindle. However actually doing it is where the problems arise as the bolt head must be held from underneath to prevent it from turning while the nut is being torqued from the top. I recently purchased an extra long breaker bar for another purpose and I will try it the next time that I do a blade change which will be soon. I have a blade grinder and usually do 6-8 blade changes a season on my 48" Tiger Cub. Blade changes with an extra pair of hands is easy to do, but the extra pair of hands is not always available when needed.
I had made up a tool to hold the blade bolt, it was a 15/16" box wrench with the other end cut off and a piece of pipe slipped onto it and welded in place. This worked fine, but I gave it to a friend who has a machine with a 72" deck and never did make another one. But still, torqueing the center blade nut from the top with an extension on the torque wrench is still problematic.
Mad Mackie in CT
