sillyboy Active Member Apr 3, 2012 #1 On a Briggs 15.5 HP Turbo Cool, what is the compression reading of a new engine? What is the lowest compression reading that it can have, and still be a usable mower engine? Thanks
J JimsRepair Member Apr 4, 2012 #2 It would be usable at 70 to 80 lbs but you would be low on power. I would guess new compression to be around 135 lbs.
sillyboy Active Member Apr 4, 2012 #3 JimsRepair said: It would be usable at 70 to 80 lbs but you would be low on power. I would guess new compression to be around 135 lbs. Click to expand... Thank You Jim
