Was working on a Intek single this morning and when running a feeler gauge around the perimeter to check for flatness while on a glass plate, and found the head to be flat, but also when doing further measurements along found that the head was cupped resulting in the area between the cylinder wall and pushrod cavity were the head gasket always blows was depressed 25 thousands.
