Must've been a thingemedjingie of sorts,..glad you got er fixed :thumbsup::laughing:
CPPS
Clutch Pedal Position Switch.
If it fails, the truck may not start or the cruise control won't work.
The factory switch is lubricated with non flammable grease to make it "arc-less". This grease is corrosive and deteriorates the 2 compression springs inside.
Finding the right spring is next to impossible. I used a shorter spring and supplemented the length with some rubber tubbing.
right now it works great, it's been a bout 7 months since I performed this jury rig so we will see.
I wish there was some good diagnostic software one could load on to a lap top and plug into the vehicle so you could troubleshoot it. That would be worth a fortune.
