chaparral electra lawn tractor
If you need help, we need more info than a name. Post all tractor and engine numbers you can find. Also tell us where you found them. If you can add pics.
It was made for Agway by MTD, using a Briggs & Stratton engine and likely an MTD trans... :smile:KennyV
Does your tractor have a three speed transaxle. If yes it is made by peerless for Tecumseh. There will be a number on the case.
