change blade
John Mitchko
HELP!! I can't get the bolt loose that's holding my blade on. It's an older Honda. I've tried everything I can think of, including buying that Blaster stuff. Have applied it several times without success. Any ideas????
Parkmower
Half inch drive breaker bar with a 6 foot pipe slipped over it.
Briana
Welcome to LawnMowerForum!
I moved your thread to the General Mower Discussion Forum. :smile:
Before you break off the bolt with the breaker bar try a tip given to me by my grandfather. Soak the bolt with a 50/50 mixture of anti-freeze and kerosene. Don't laugh, it works. When you reassemble, use anti-seize.
okiepc
I have found that a 1/2 inch air impact wrench will make short work of it, the vibration seems to free the bolt better than a break over bar. Just my opinion:smile:
robert@honda
Don't see anything unusual about the blade/holder parts...the 8 x 50 mm blade bolt may have rusted/decayed quite a bit over the years and fossil-ized itself. Be careful with too much leverage and don't break or bend anything.
attachment.php
A dab of neverseize on the bolt and use of a torque wrench set to 22-25 lb-ft should prevent problems in the future.
-Robert@Honda
Caveat: I work for Honda, but the preceding was my opinion alone.
John Mitchko
Thanks Robert. I'll use the diagram when I get the new blade. Another question, if I may... The brake lever is frozen. I'm trying to unfreeze it with that Blaster stuff but I may have to change it. How do I get it off without tearing the whole machine down? Any thoughts??
attachment.php
-Robert@Honda
robert@honda
Are you talking about the flywheel brake lever by the handlebar? How about a photo, so I can see exactly what you've got?
The flywheel brake lever has a cable/spring to hold it away from the handlebar when released. Is it frozen up next to the handlebar or away from it? Here's a drawing:
-Robert@Honda
John Mitchko
When I got the mower going the other day the flywheel brake lever by the handlebar wouldn't move to stop the motor. I had to poke the sparkplug off with the broom handle to stop it. So I got a straw to fit the Blaster stuff and am trying to pump it down the cable. If I have to take the cable off, I can't see how to get under the top of the mower to get at it. Seems like it's hidden under there with no easy access.
-Robert@Honda
