So I bought the needle bearings, seals, and drill bit. The drill bit ($15) got really dull near the end of the second hole, but it made it. Maybe more $$ on the drill bit would be a better call. I used the bench vice and a steady hand, and it worked fine. Epoxied everything up last night, and reassembled it this morning.
The mower pulled backwards very easy. I started the mower and did a 5 minute test lawn cut. It pulled back very easy. Surprisingly, it nearly leaped out of my hands when I engaged the drive! I am very happy so far. The true test will be to see if it lasts beyond one mowing season. This is my 5th year with this mower, and I have had to tear the rear drive down at the end of every mowing season, clean and re-lube it.
Thanks, Briantii. Great fix, and great instructions.
