joelwcassell
- Apr 1, 2019
- Threads
- 1
- 1
Hello,
I am working on a Briggs horizontal opposed twin in a Cub Cadet 582. The model number of the engine is 401417. I am replacing the engine with a donor Briggs, but its throttle and governor linkage is different than original. I want to put the original setup back on, and am trying to figure out how to remove and adjust the governor arm.
A link to the diagram is below:
https://www.partstree.com/parts/cub...rden-tractor/air-cleaner-carburetor-governor/
My question is how does the governor arm come off? It has a clamping bolt through it, I assume that if I take that bolt off I can pull it upward and off? It seemed pretty tight even with the bolt out so I didn't want to damage anything.
In terms of adjustment I have heard that you need to turn the upright post all the way counter clockwise and push the arm forward to the throttle is closed, and then tighten. Does that sound right?
Joel
Joel
